Maxi trunking running around consumer unit Discussion ThreadMaxi trunking running around consumer unit Electrical Advice
Hi all, recently seen a wylex consumer unit install video, they use bush and couplings to connect to the pvc trunking running horizontal on the top on the consumer unit, is this necessary? They also show another option using strain relief grommets (inside the trunking going into the CU) How would you go about joining it to a hager unit where they have the square knockouts and also not possible for strain relief grommets either. Ive always believed it was sufficent to run the trunking butted up next to it.
Maxi trunking running around consumer unit for the original thread on Electricians Forums
