Mechanical Protection for Tails between Meter Cupboards on outside wall Discussion ThreadMechanical Protection for Tails between Meter Cupboards on outside wall Electrical Advice
Hello, what products are people using for suitable mechanical protection in compliance with regs for the following job?
Existing Meter Cupboard recessed into outside wall adjacent to driveway on a domestic property with incoming Mains Supply, Meter and Tails.
Requirement to add an additional surface mounted GRP meter cupboard adjacent to the existing one to accommodate a second Consumer Unit. Meter Tails will be taken from Henley Blocks inside the existing Meter Cupboard, routed down through the bottom, horizontally along the wall and up into the bottom of a second meter cupboard.
I have seen waste pipe used in this situation in the past. What products do you use?
Many thanks,
John.
Mechanical Protection for Tails between Meter Cupboards on outside wall for the original thread on Electricians Forums
Many thanks,
John.
