Discuss Metal Capped Mosaic in the Australia Tiling Forum area at TilersForums.com.
Q
Qwerty
Here is the last job I did using metal capped mosaics. Mapeiglitter grout which tried its hardest to scratch the metal! I had to cut the metal on the shower tray plinth, killed my ATS turbo blade by the end, but was worth it
bcd-87
I
Italy
macten
1,158
Nottingham
If you end up having to cut slithers the metal caps will come off no matter what you cut them with - most are spot glued in the middle.
Lovely bathroom that Plan tec.
This is a kitchen I did last year
I
Italy
Reply to Metal Capped Mosaic in the Australia Tiling Forum area at TilersForums.com
Hello, I’ve put up mosaic tiles and some of them (the shiny metal ones) have a protective film...
Hi, new to forum and first post, after some advice. Recently had the chamber of my fireplace...
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully...
Metal Capped Mosaic
    Votes: 7 5.2%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.9%
    Votes: 16 11.9%
    Votes: 33 24.4%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.8%
    Votes: 18 13.3%
    Votes: 15 11.1%
    Votes: 7 5.2%
    Votes: 3 2.2%
    Votes: 3 2.2%
