DHTiling
Ok.. I am interested on some discussion on how you prep and prime an Anhydrite screed ready for tiling.
What method of sanding do you use , even if the screed is low laitence ..
What method of priming do you do ..
Do you use Acrylic primer or maybe epoxy primer.
Do you use a cement based adhesive or maybe a gypsum based adhesive..
I am interested in how many have tiled to anhydrite and how many have had a failure.
The discussion is basicly to see how many have tiled to one and the way they have done it to see if a majority way is used.
I am gunna ask Alan from lafarge to not input in this discussion as i want an unbiased approach to the results and methods used.
There is an awful lot of conflicting advise on the prep and priming etc..
So please do have your say and input and lets see who does what and uses what..?
Many thanks Dave.
Many thanks Dave.
