rj1884
Hello
A bit of advice if possible please.
I'm just about to have a go at tiling my bathroom using white ceramic metro style tiles.
The area I'll be tiling is the bath/shower surround tiling 2walls from the bath tub to the ceiling. I'll be using the metro tiles which are 200x100 cms and 6 mm thick and I will do it in the brick bond style.
When planning where to start should I try and make sure that where the end of the bath is where the tiles will stop should I make them all cuts so they have a nicer finish to fit the trim due the different thicknesses or does it not matter.
Also what thickness and type of trim would be best for this and a window I have to tile around.
i hope that all makes sense.
Thanks in advance
Thanks in advance
