Discuss Metro tile trims. in the Canada Tile Advice area at TilersForums.com.
DaG
Hi all.
Im tiling my kitchen with metro tiles and fixing them in a brick pattern. Because of the beveled edges and having to start every other row with a half tile I have a problem with edge trims. The beveled ends of the tiles are about 5mm thick whereas the cut ends of the half tiles are 8mm. Is there a favoured way of fitting trims at exposed ends of rows to get around the different thicknesses?
Thanks for any help.
DaG
I can't tile whole walls unfortunately, the way the kitchen is laid out.
Ive just been looking at metal trims which were an angle without any radiused edge. With these fitted all that would show would be a strip of metal and it will probably be easier to blend in the the two thicknesses of tile with grout. The store only had 12mm in these so I'll leave it till tomorrow and have a better look around.
Thanks for the replies.
DaG
Right idea but I always use Silicon down the side of trims, if the trim gets a knock it could crack the grout and wouldn't look very good
Im not a fan of Silicon it always gets where you don't want it. I'll do what you say though but use A flexible acrylic sealant and see how that goes.
Reply to Metro tile trims. in the Canada Tile Advice area at TilersForums.com
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
Hi everyone Looking soon at retiling a shower enclosure walls at a local leisure centre. Once...
Looking for some technical advice on these tiles please. Our installers fitted this CaPietra...
Metro tile trims.
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
