Discuss Micro joint infill on top of grout ? in the America Tile Forum / Advice Board area at TilersForums.com.
Hi tiler has used micro joint infill in few places to reduce stress (decoupling matting also used) - before putting in the gap between tiles put grout in to stop the infill resin running away - doesn’t that defeat purpose of the in fill ? As it happens used way too much resin and had overspill each side of line and whatever I did still looked a poor job so removed the resin and going to do it myself but can see quite a bit of grout was used before job done so in fill will only be a few mm deep - is this a problem - should I be trying to scrape grout out as well - be a nightmare job as 25 metres of infill and bad enough getting the cured infill out ? Any advice greatly appreciated, Loz
Reply to Micro joint infill on top of grout ? in the America Tile Forum / Advice Board area at TilersForums.com
gamer1
  • Sticky
Hi all, I live in Cyprus. Bought a new build top floor flat a couple of years ago with a roof...
USA Tile Forum Popular
America Tile Advice Trending
Swansea
What member type are you?
  1. Homeowner
    Votes: 5 4.6%
    Votes: 8 7.3%
    Votes: 6 5.5%
    Votes: 30 27.5%
    Votes: 14 12.8%
    Votes: 28 25.7%
    Votes: 3 2.8%
    Votes: 2 1.8%
    Votes: 19 17.4%
    Votes: 18 16.5%
    Votes: 13 11.9%
    Votes: 5 4.6%
    Votes: 3 2.8%
    Votes: 1 0.9%
