K
kaharrison9
Hi all
Thoughts would be appreciated from anybody whose used Marmox backer boards before on walls before.
First time i've used these products before and have looked them up.
In the shower enclosure one wall is stud and the other block.
I looked at the Wedi manual and they say a minimum of 10mm,aquapanel 9.5-12.5 is fine and i've assumed the Marmox 10mm would be the same,which i've ordered.
Have received the boards today and inside is a panflet saying on walls 20mm is advised.
Has anybody used 10mm marmox on walls before and in theory is the Wedi and Aquapanel stronger as they say to use 10mm is fine?
Will be mechanically fixing the boards as well
Cheers for your thoughts
Kev
Kev
