Hi guys,
Just a quick question regarding packing out the difference between the tile height and the plasterboard.
I've stuck a few mirrors on before but they've always been on a solid wall rather than plastboard, and these tiles are thicker than anything ive used in the past, being 10mm.
I've done some research online and most people suggest either hardie backer or plywood to pack out the difference.
I've decided to go down route of getting 5.5mm moisture resistant plywood that I had planned to stick with no nails type adhesive and screws, ( maybe exterior grade wood glue might be better as its wood to paper ?? ) then stick the mirror on with mirror grip adhesive.
Does anyone see an issue with this? I had decided against the hardie method due to the fact that its slightly thicker and the tile adhesive would bring it out further, and I wasn't sure how well silicone would stick to hardiebackers dusty surface.
Mirror is 1.2m x 1.2m
Thank you!
Thank you!
