Discuss Missing information about Marmox tile backer in the Canada Tile Advice area at TilersForums.com.
jev
london
Planning to install brick imitation porcelian tiles 250x250 size in dinning room, decided to go with studs on brick wall ( 20.5mmx 45mm,because need to cover some pipe work) and will cover with Marmox 12.5 . There is very light official manual, so please, could some one explain me a bit more in details:
1. official manual states that 20mm sheet goes on 600mm centres, 10mm sheet goes on 300 centres, what about 12.5? 400? if so then sheet is 600 and centres 400 how to fix them? horizontally? what about 1200mm edge support ?
2. in official manual nothing said about nogging, do i need put noggins to support end of sheet? if every 300m centres i would think is not needed?
3. official manual says to use drywall screws with Marmox washers, on this forum found people advising to use SS ones, would i need SS if installing not in wet area.
Thank you for advice!
Boggs
1,118
Uk
1. Studs at 300mm on 12.5mm
2. I add noggings on board joints to stop any flex.
3. I use stainless screws in wet areas, but it’s not really necessary, goldscrews from Screwfix will be fine.
Tile Fix Direct
TF Official Sponsor
153
743
Aldershot
Be pleased to sell you Marmox, waterproof tapes, stainless screws etc;
Reply to Missing information about Marmox tile backer in the Canada Tile Advice area at TilersForums.com
I would very much appreciate the advice of anyone who has fitted Marmox boards as I have decided...
6K
Hi All For my own sanity need to clarify that ProWarm BACKER-PRO Tile Backer Board 10mm is as...
16K
Flintstone
F
U
I needed to replace 3 tiles and in removing the old ones the backer board has got damaged - the...
5K
TJ Smiler
N
Hi all, first post so play nice! I am about to start a rebuild of our bathroom. It is stud...
White Room
N
Hello everyone a very happy new year to you all!! It’s been a while since I last posted...
13K
Gazzer
london
What member type are you?
  1. Homeowner
Business Name
na
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
