Discuss Mitras semi buried gas meter box - welded meter outlet fitting Discussion Thread in the Plumbing Advice area at TilersForums.com.
Hello, I went to a job recently that had a smart meter in a mitras semi buried gas meter box. See pic attached. The meter outlet fitting is a factory made welded fitting that allows the meter outlet to line up with the outlet hole on the box. It is not something I had seen before and I was wondering how one would deal with these if you needed to upgrade the pipe run to 28mm as the fittings seem to be 22mm.
Mitras semi buried gas meter box - welded meter outlet fitting for the original thread on Plumbers Forums
Reply to Mitras semi buried gas meter box - welded meter outlet fitting Discussion Thread in the Plumbing Advice area at TilersForums.com
Plumbing Advice
Tags
None
    Votes: 9 5.6%
    Votes: 17 10.6%
    Votes: 11 6.8%
    Votes: 44 27.3%
    Votes: 21 13.0%
    Votes: 38 23.6%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.7%
    Votes: 19 11.8%
    Votes: 17 10.6%
    Votes: 8 5.0%
    Votes: 5 3.1%
