Guest viewing is limited
Discuss Mitre cutting ceramic wall tiles. in the UK Tiling Forum area at TilersForums.com.
Gazebo
Hi all,
Hope you have all had chance to enjoy our recent spell of good weather,
Just a quickie a customer has asked me to mitre cut the ceramic wall tiles on a vertical join, is this possible to do without the glaze chipping.? I have always used trim for this and if it was travertine or limestone it would be ok but I am not sure about ceramics.?
If anyone has undertaken this kind of thing before and has any photos or tips i would be very appreciative.
Many Thanks
Gary
Gazebo
Thanks for the speedy response, I use a Durator diamond blade from screwfix in my mini grinder, about £35 if i remember but when i use it to cut/trim tiles it seems to chip the glaze, i must be doing something wrong or the blade might be blunt.? not sure, do you score the tile 1st then snap cut and just grind the 45 out of the back of the tile, how do you hold it when doing it.? tried the angle thingy on my plasplugs but its not that accurate. Maybe there is a reasonably priced table sliding cutter that would help.? any more ideas.?
Cheers
Gary
peckers
I use a rubi wet tile cutter to do my mitres with, If it is a full tile you want to do the mitre on then just run the tile threw the saw on the mitre just removing the biscuit and keep the blade about a 1mm away from the glaze. there for not getting any chips atall..
If you havent got one of these cutters then just grind the biscuit away with an angle grinder being careful not to touch the glaze.
If you need the mitre on a cut tile then you can scribe it and snap it with a dry cutter, and then remove the biscuit with an angle grinder being careful not to touch the glaze, then using a carborrondon stone(cant spell lol) with water you can rub down the edge of the tile making the glaze smooth
When installing the mitred tiles leave a joint of approx 1mm to allow you to fill with grout
Works fine for me:thumbsup:
peckers
Thanks again,
So when i am setting out will i have to make sure that is a full tile up the vertical joint.?
otherwise i will have a cut tile against a full field tile which may not look so good.?
They are pillars being made in front of the window reveal if that makes sense.
Will try the method you have suggested 2morr at work and see how i get on.?
:8:
If when setting out it works with a full tile on the edge and it looks the best way to go then fine, If however it dosen't then you can put a cut tile on the end as a mitre if you are doing the mitre the way i described then mitre the cut edge and rub down with a carborrondon stone..
Practice makes perfect:hurray:
Time's Ran Out
Gazebo -
1) If you take your ceramic tile on your knee with the glazed side facing you.
2) Have a small panel pin hammer and gently tap the back edge of the biscuit away - being careful not to chip the glaze.
3) Take a rubbing stone and gently smooth this back edge at a 45degree angle up to the glaze.
4) Fix tiles with small gap for grout.
OR
1) Go and buy a wet saw with mitre slide worktop - works every time circa 1980.:thumbsup:
Timeless John.
Reply to Mitre cutting ceramic wall tiles. in the UK Tiling Forum area at TilersForums.com
Beginner DIY Tiler, I'm contemplating drilling (with ceramic tile carbide tipped drill bits)...
Looking for some technical advice on these tiles please. Our installers fitted this CaPietra...
Hello All, First post in this forum so forgive me if this has already been posted before. From...
Hi Everyone thanks for having me on the this forum ill try not to break any rules. I am diyer...
