Just trying to get all answers before starting a DIY tiling job. If your mitering the tiles of an external corner but wanting to trim the top with box edge trim, will there be an edge sticking out at the corner of the trim of 1 or 2mm, due to the tiles being mitred so the grout will be at 45degrees on the corner rather that a 90degree finish.
Hope that makes sense.
Also wondering if best to mitre the box trim or use corners?
Also if using external corners would you also use the same corners for internals aswell to keep it all looking the same?
