Discuss Moisture meter.... in the Australia Tiling Forum area at TilersForums.com.
Thanks Ajax, I have found out from quick research the BS approved method.
An indication would be good enough for me, then more thorough investigation could be undertaken if necessary.
Knowing most of my customers, I think a surface dpm will be incorporated anyway, as time is always critical. I don't think many would even wait 48/72 hours for a proper test.
So , I do a quick test, it says it's dry. Screed has had 4months to dry. All's good.
Or
I do a quick test, it says moisture content is too high/borderline.
Screed has only had 2months to dry.
I can then give the customer the option to:
Wait a few weeks then 're-test
Use ditra mat or similar
Or do a more thorough investigation to give an indicatmion of required time to reach acceptable dryness and/or confirm the need for ditra mat.
I've emailed a couple of meter supply companies to see what they recommend.
I've only come across a few anhydrite screeds over the years, they don't seem to be very popular for some reason.
The 2 I have tiled I used ditra mat as timescales were critical, still work for the people involved with those so would know of any problems.
And 1 I quoted for and supplied a lot of specifications for, I didn't get the job. The customer went with another tiler that said all this prep is unnecessary and no need for the matting. I pleaded with the customer to do his own research and ensure the other tiler did the proper prep, and told him I wasn't bothered about not getting the job.
Don't know how it all turned out, but I definitely know it wasn't dry enough To tile directly onto
Reply to Moisture meter.... in the Australia Tiling Forum area at TilersForums.com
