Discuss Moisture resistant boards prior to tanking? in the UK Tiling Forum area at TilersForums.com.
Aston
i would go for the aqua panel because its mould resistant and you can get a lot of condenstation behind the boards where the hot and cold water pipes are situated whether thats a shower enclosure or bath/shower.. its not just the front of the boards you need to consider when dealing with shower/humid areas...aqua panels are stronger, hold more weight, mould and water resistant so if its a straight choice between the 2, then its the aqua panel for me..
Rich
ive checked out the marmox and the costs are so expensive for all the parts and washers plus there slightly smaller than aqua.
Can aqua panels be used on top of plywood prior to tiling a floor? Or does it have to be hardie?
Yeah you can use aqua panel on the floor. Have a read through the installation instructions tho, I think they recommend the same fixing method as Hardie but it has been a long time since I used it.
Reply to Moisture resistant boards prior to tanking? in the UK Tiling Forum area at TilersForums.com
Hiya all, I'm a DIY gal on first bathroom. Wondered if you could check out my plans and let me...
Hello all. I'm doing a total refit of my bathroom, including the floor which is water damaged...
Hi everyone, I'm looking for some advice on final floor buildup. We're installing a shower tray...
    Votes: 5 4.6%
    Votes: 8 7.3%
    Votes: 6 5.5%
    Votes: 30 27.5%
    Votes: 14 12.8%
    Votes: 28 25.7%
    Votes: 3 2.8%
    Votes: 2 1.8%
    Votes: 19 17.4%
    Votes: 18 16.5%
    Votes: 13 11.9%
    Votes: 5 4.6%
    Votes: 3 2.8%
    Votes: 1 0.9%
