Discuss More rubbish from B & Q in the Canada Tile Advice area at TilersForums.com.
Just finished a shower room using 50 x 20 cm Cortese Blanc satin that the customer got from B & Q fixed using Weber spf white yesterday, returned this morning to grout,started to grout and notice a lot of dark shading all around the edges of the tiles some were even a lot darker over the whole tile did show the customer and they were happy for me to continue,the only thing I can think off is there must of been bleed thru from the adhesive or water stain from the washing of the tiles,so just like you chaps to be aware of this problem if you come across these tiles,apparently the customer thinks these are a new range I have told him to complain but I expect that will fall on deaf ears,just glad the customer was so amicable about it I had visions of me ripping them all off,they also cut badly very ragged edge when cut on a dry tile cutter did use the angle grinder which I am glad I did dread to think what they would of looked like if I used my wet cutter.
Reply to More rubbish from B & Q in the Canada Tile Advice area at TilersForums.com
  • Suggestion
Topps Tiles in-store or online - Genuine Feedback, Positive or Otherwise. I used to work in a...
  • Sticky
6K
Hi, apologies if this has already been covered before but I couldn't find anything in the forum...
7K
Tilers Forums on FB
