Discuss Mosaic glass tile cutting in the The Welcome Forum area at TilersForums.com.
Thanks for joining me and as most I've read have come across a problem. Wife has bought glass mosaic tiles, the sheet is 30x30 made up of chip shape oblongs which are set out as you would lay bricks ( top one straddles the under two by half+half ) the official cutting method wording is:
If you have to cut the glass we recommend scoring them on a tile cutter and then use nibblers to snap after scoring. Knock the sharp edges off with a diamond stone if required.
My question to you all is which tile cutter, nibblers do I need to purchase or is any available on eBay etc acceptable?
Thanks in advance for your help
MGS
Reply to Mosaic glass tile cutting in the The Welcome Forum area at TilersForums.com
Advice Hi guys, got some 60cmx60cm porcelain tiles to lay in a hallway with a modular pattern...
Hello, I hope you can help. I'm get despondent cutting 9mm glazed porcelain tiles, 300 x 900mm...
Hi all, I live in Cyprus. Bought a new build top floor flat a couple of years ago with a roof...
Hi all, I'm due to install Fired Earth glass mosaics (*££!!) and am a bit nervous about safety...
    Votes: 9 5.5%
    Votes: 15 9.1%
    Votes: 12 7.3%
    Votes: 49 29.7%
    Votes: 20 12.1%
    Votes: 38 23.0%
    Votes: 4 2.4%
    Votes: 21 12.7%
    Votes: 19 11.5%
    Votes: 17 10.3%
    Votes: 8 4.8%
    Votes: 3 1.8%
    Votes: 5 3.0%
