Discuss mosaic tiles in the UK Tiling Forum area at TilersForums.com.
UKTT Darren
TF Official Sponsor
Subscribed
195
828
North East
Depends on what they are made of, if natural stone wet saw with white cement adhesive, grout straight away.
Ceramic, White tub gear,cut on dry cutter, trowel also depends on how thick, use the appropriate depth so as adhesive wont come through, pad them down with your grout float to ensure an even surface, space by eye so that the whole lot looks like one sheet
GazTech
sorry gz did i say that f and g word,im new to tiling only learned in 83 i need more practice:coffee:
I'll let you off T,remember we are role models to these youngsters ,Never mention the F & G words again! ps beat my asteroids score did it to spite me eh? :wink_smile:
E
Elliott
If glass remember to open ALL boxes and look for batch shading, use BAL mosaic fix (white) great stuff. cut with 8mm wheel in cutter and use DMT diamond sharpener on edge (machine mart) or diamond block (4 grades) from B & Q £9. Remove and turn all half pieces on external corners. Like licking a 9v battery - people love to run there finger along them!!
H
howard
Hi Mate
It Went Very Well I Used Bal Mosaic Tile Adhesive & 4mm Trowl . The Bal Was Really Good To Use . The Only Problem I Had Was The Customer Had Bought Bal Wide Joint Floor Grout To Use And Insisted I Used It To Grout I Thought This Made The Finish Look Afwul . The Tiles Took A Bit Longer To Put On Than I Thought Just Take Your Time & Read All The Advise I Was Given I Thought They Were Quite Easy To Lay
Good Luck
Reply to mosaic tiles in the UK Tiling Forum area at TilersForums.com
mosaic tiles
    Votes: 8 5.9%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.7%
    Votes: 16 11.8%
    Votes: 34 25.0%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.7%
    Votes: 18 13.2%
    Votes: 15 11.0%
    Votes: 7 5.1%
    Votes: 3 2.2%
    Votes: 4 2.9%
