Discuss mosaic tiling prices in the British & UK Tiling Forum area at TilersForums.com.
F
Fekin
If I was you, I would be looking for near perfect walls to tile onto if the tiles we're propper mosaics on netting unless they are mosaic effect ceramic tiles, becuause mosaics on a netting background will follow every lump, bump and dent in the walls.
Main thing I find with mosaics is the fitting isn't really much longer, it's just the grouting that can take a lot longer, it all depends on the mosdaic size.
Generally, I'd charge £5 to £10 more per sqm for them, depending on the mosaic size.
Tilestiles
Tips in fitting mosaics as follows. Use a small notched trowel (3-4mm). They normally come in pads of tiles, you should fix these brick bond style. Ensure walls are good regarding flatness otherwise you will have big problems. When fitting pad of tiles to wall, press home using grout float for a nice even look. Use a white adhesive as the grout lines can be a pain to keep clean as there are so many of them when fitting mosaics. Here endeth the lesson!! - Lol
Reply to mosaic tiling prices in the British & UK Tiling Forum area at TilersForums.com
Hello one and all, I have a 240m2 floor tiling job to price, including a tile upstand edged with...
We had a wet room fitted by a large company. We have issues with a few large steps where the...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
