Discuss Most suitable products to use.... in the UK Tiling Forum area at TilersForums.com.
BJD
Hi All,
I have a walk in shower which is tiled with natural slate - within the shower the drain has a cut out thin section (which lifts out for cleaning purposes) and this also contains the matching slate with the floor.
Basically, the thin cut out slate has loosened and now lifts out - I have attached a top down view of the drain along with a close up of the underneath of the thin tiles. I would greatly appreciate some advice on the items below if possible:
(1) I need to get the mastic or adhesive (don't know what it is) off the back of the thin tiles - what would be the best way to do this?
(2) What would be the best product to use to re-fix these thin tiles?
Hope to hear from you soon,
Cheers, Brad
BJD
Apologies - now attached.....
AliGage
Subscribed
4,531
1,188
Peterborough, England
I'll be completely honest. I have never done a channel drain like this, and have never fixed tiles to metal.
I can't recommend an adhesive or primer either. BUT....I recommend this stuff in another post, it's a must have IMO. It would definately stick these together.
CT1 Sealant, Adhesive, Bonding, Glue, Silicon
I'd fix the slate like you would if you were using adhesive. I.E create a good and consistant bed of the CT1. I presume these will be grouted in. If the grout fails at all you don't want water swimming under the slate. So i wouldn't fix them with a dot and dab method.
If anyone can suggest an alternative using more "tiling" methods i'd be keen to know the answer. I'm stuck on this one.
Reply to Most suitable products to use.... in the UK Tiling Forum area at TilersForums.com
Hi there, Has anyone had any experience with this product and what was you opinion on it? I’m...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
