Discuss My biggest tiling job yet in the Canada Tile Advice area at TilersForums.com.
Carl Haynes
Tell me about it. I did a 40m square floor in a barn conversion a few weeks ago but that was corridor, hallway, entrance hall,cloakroom etc. Anyway this garage is for a pretty well off guy to show off his collection of Aston Martins. So he'll obviously drive on and off it a bit.
Haven't seen the tiles yet but I know they're 909mm square and I think they're porcelain. The substrate is a 50mm flow screed over 120mm kingspan insulation with about a metres width of water pipe underfloor heating round the edge. There are no expansion joints in the substrate. Appreciate your help on this one mate.
Just Rizzle
900 x 900 to drive cars over you need perfectly flat floor and100percent solid bed as your going to have 2tons of car parked and running over it.
from what you said about how the floor is made up id give this one a miss. the movement is going to crack the tiles even with 100 percent coverage, theres goingto betoo much stress on the tiles with all the insulation beneath it and only 50 mm screed
I
Italy
same,
900mm square, could also be 30x30 cm?
John Benton
1,138
Leeds
Ajax123
1,213
Lincolnshire
Interesting point - 50mm screed on kingspan - would that be strong enough for driving on? @Ajax123
Standard gypsol classic has compressive strength of minimum C25 and Kingspan has a compressive strength of 150kPa. If the Aston Martin weighs 2tonnes that's 2000kg so 500kg on each wheel. That will exert 0.5kN force. So it is perfectly strong enough. Done loads of garages and car showrooms. Never had an issue
Ajax123
1,213
Lincolnshire
the size of tiles on 50 mm screed on kingspan 120 mm is the problem. 900 or 300 the stresses from the cars are the same 2 ton car on 4 points of contact approx 90 cm2 for each tyre the floor is going to crack with out a doughy the screed is too thin
But because they are pneumatic tyres equally space on a solid chassis it acts as a uniformly distributed load so the actual down force is much less than would be expected. Lost count of the number of garages I've done in flowing screed over the years. Never had an issue with weights. I think the heaviest I know of is a hummer. Unless a light aircraft weighs more... done quite a few light aircraft hangars as well.
Reply to My biggest tiling job yet in the Canada Tile Advice area at TilersForums.com
Hello, first post, asking about career change and possible entry route into the industry. I know...
    Votes: 5 4.6%
    Votes: 8 7.3%
    Votes: 6 5.5%
    Votes: 30 27.5%
    Votes: 14 12.8%
    Votes: 28 25.7%
    Votes: 3 2.8%
    Votes: 2 1.8%
    Votes: 19 17.4%
    Votes: 18 16.5%
    Votes: 13 11.9%
    Votes: 5 4.6%
    Votes: 3 2.8%
    Votes: 1 0.9%
