MPC
Hi all.
I'm just wanting a little help regarding my first tiling project, my bathroom.
One of the walls is out of plumb by quite a bit so I plan to plasterboard the bottom half to sort it out.
Which sort of plasterboard would you recommend for it, does it need to be waterproof?
Also would it have to be treated at all prior to using adhesive & starting the tiling.
I am planning on using cement based adhesive, should I go for rapid set or not?
I also have an area where I'm going to have to tile onto tile (I know its bad practice but they cant be removed without damaging the walls) which adhesive should I be using for that?
Any help much appreciated
