Discuss my job for next week! in the UK Tiling Forum area at TilersForums.com.
same with that floor too, that plan is nothing like the one i drew with the measurements and approx angles. all them look square :mad2:Ive got one to do myself in the next month and there aint one wall paralell to the other and not one square corner either
the borders will have to go in prior to the rest but i will have to work from the centre out to keep it symetricalyou'd start with the border tiles, wouldn't you? and then fill in.
cracking advice from an old proMorning - You need to find a middle straight line - dry lay a few tiles in pattern (allowing for joint size) and measure accross the diamond to gain the position of 1st border line.
Unlike your picture, I'd finish all the edges of the main design on a half triangle powder blue - this means you wont have any red against the red of the linear border.
Measure the width of the border and use the outside powder blue tile as your variable size filler tile to the skirting and to take into account any wall movement.
The process is reapeated for the end of room measurement as well.
The most important part as you are aware is the time spent looking before your first tile is fixed - don't rush the setting out and measuring.
Good luck.
Reply to my job for next week! in the UK Tiling Forum area at TilersForums.com
