tricky15
Hi Guys
You may all be aware that i've been asking questions about tiling my bathroom for about a month now, and all your feedback is going to be put into action starting tomorrow.
Recap
I've got 600 x 300 x 10 porcelain tiles 18.5kg per 0.9m2 to fix to walls in bathroom over bath area which will consist of a over bath shower.
Method
1 Remove all walls down to studwork (already done) got some good photo's i'll add when job progresses.
2 refit new plasterboard (not skimmed)
3 apply mapei tanking kit to shower area.
4 fix tiles to wall using keraflex maxi 8mm to 10mm trowel
5 seal porcelain tiles
6 grout using bal superflex white grout.
I know marmox or something similar would be best but this shower will only be used once a day if that by my daughter and thats a few years away yet as shes only 2 lol we have the shower in the ensuite.
The ensuite is the next task that will be done no expense spared marmox will be used its used 3 to 4 times a day!!!
please leave feedback on what you have read i value your comments, wether i should use a different addy or grout anything.
ps i will show pictures of me job for use to have a look
Richard
Recap
Method
Richard
