Discuss Nearly there - a bit more advice please. in the British & UK Tiling Forum area at TilersForums.com.
mick7
Hi All
Nearly laid my first floor, 5 sq metres of 60 x 60 porcelaine certainly was'nt the easiest but nearly there thanks to all the help from the forum.
A few more questions please:
1. How do you mark your lines for cutting on your tiles. I marked mine with chinagraph pencil and having a hell of a job getting it off. Used Lithofin intensive cleaner but still not shifted all of it. Any advice welcome.
2. I've sealed the tiles once with Lith. FZ impregnator. Should I do them again before or after I grout. I've got a seperate sealant for the grout. Advice please.
3. I've got the plumber coming in a few days to fit a back to the wall toilet. I want to protect the lovely new tiles and grout. I was thinking of covering the tiled area with sticky back plastic, the stuff you can protect carpets with and then put some hardboard etc on top. He makes a hell of a mess and wont give a dam about my nice new tiles. Advice please.
many thanks
sweaty sock
Hi Mick - I mark my cuts with a felt tip for dry so wipes away easy or pencil for wet cuts.I fit bathroom suites all the time - i would cover the tiles with a good dust sheet and protect on top with cardboad if u can get it.By the way - who is drilling the holes in the porcelain floor tiles for toilet fixing?:whatchutalkingabout
DHTiling
The tiler is drilling the holes for the toilet I hope !!!!
Otherwise it will be me, i've got those 365 drills bits which are supposed to be excellent.
No more china graph pencil for me then, a pencil it is.
Any ideas how to get the china graph marks out?
Try some nail varnish remover......great for that type of stain....do a test on some scrap tile first..........
tops111
Bought a set from 365 last month.Went through porcelain 10mm no bother.Lent one to a plumber to try and he blunted it on one hole (he said he forgot to keep it wet!!):furious3: . Mine have been good for 6-7 holes but then i just use them on the softer ceramics,they go through like hot knife through butter! Good bit of kit if you use now and again.Maybe go for more expensive set up if using all the time as could work out costly.:thumbsup:
Reply to Nearly there - a bit more advice please. in the British & UK Tiling Forum area at TilersForums.com
Hi all. After living in my property for over 7 years I've recently discovered the type of tile...
After some advice please..... We have approx. 50sq m of Dijon limestone 600 x 90 x15mm and also...
    Votes: 9 5.4%
    Votes: 17 10.1%
    Votes: 12 7.1%
    Votes: 47 28.0%
    Votes: 21 12.5%
    Votes: 40 23.8%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 23 13.7%
    Votes: 19 11.3%
    Votes: 17 10.1%
    Votes: 8 4.8%
    Votes: 5 3.0%
