Adrian mcc
I would look at altering the legs on the bath the bath has defiantly moved. There usually 2x m10 nuts on each leg that can be altered to higher or lower the bath. Is the plasterboard sat on bath to
Discuss Need advice caulking a bathtub when the gap is BIG between wall tiles & tub. Thanks. in the Canada Tile Advice area at TilersForums.com.
Hi Adrian:I would look at altering the legs on the bath the bath has defiantly moved. There usually 2x m10 nuts on each leg that can be altered to higher or lower the bath. Is the plasterboard sat on bath to
Why would you want to fill in that gap.........rip those minging tiles off, level bath and re-tile.
Reply to Need advice caulking a bathtub when the gap is BIG between wall tiles & tub. Thanks. in the Canada Tile Advice area at TilersForums.com
