Guest viewing is limited
Discuss Need advice on adhesives, grouts and preperation for my first time tiling in the UK Tiling Forum area at TilersForums.com.
D3ANO
Hi, I am about to tile my bathroom (approx 30 m2) walls and floor with a 360mm x 270mm glazed ceramic tile the walls a plasterboard which have been painted (from reading other posts i know i'll have to remove the paint) but after this will i need to prime the plasterboards?. The floor has an approx 18mm chipboard sitting on top of a concrete floor. from further reading people seem to recommend removing this and replacing with ply which i don't mind doing as i want to do a nice job but after i have lined with ply which adhesive would you recommend and also would i need to prime first?
nybor62
1,083
rotherham
prime walls after removing paint, i would use a white powdered adhesive , your tiles are a bit big for a ready mixed addy check out mapei adhesives tile giant if theres one near you.
as regards the floor what condition is the chip board in , how is it fastened down
if secure you could over lay with hardi backer board, other wise you could remove the chip board and use ,ditra matting
D3ANO
The chipboard is in good condition and as yet is not fixed down to the concrete underneath but i will screw and plug it down and take your advice and use a backer board. thanks for your help
D3ANO
If you replace the chipboard with ply (is it onto battens on the concrete?), priming requirements will depend on the adhesive supplier you choose. Some say to prime, some don't so follow the advice of your chosen supplier. Incidently seal the back face and edges of the ply before you lay to reduce the possibility of moisture ingress.
Ii'm probably going to go with Bal for my adhesives and grouts i know ill have to use a flexible adhesive for the floor will i also need to use a flexible grout? thanks for help
Reply to Need advice on adhesives, grouts and preperation for my first time tiling in the UK Tiling Forum area at TilersForums.com
Hi, Need to choose a grout for the above. For the black floor tiles 300x600 am thinking either...
