Discuss Need advice on cutting ceramic tile in the British & UK Tiling Forum area at TilersForums.com.
Buzzcutz
Hello.. Newbi here so hope someone can help,Have a builder laying floor tiles (60 x 30 ceramic)and we need to cut 10mm strip off these tiles to use to fill a gap between channel drain and existing tile (for shower). He has had a couple of attempts and says it can't be done, (cutting a clean 10mm piece off to use)Can any confirm the above? And if so what is the bet option to use I.e. Angle grinder with diamond cutting blade?Cut would be along the 60 edgeThanks
DHTiling
Not sure what you mean , any pics plz
- Sent from my iPhone
Reply to Need advice on cutting ceramic tile in the British & UK Tiling Forum area at TilersForums.com
Beginner DIY Tiler, I'm contemplating drilling (with ceramic tile carbide tipped drill bits)...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
