Discuss Need help with cuts in the America Tile Forum / Advice Board area at TilersForums.com.
Hi guys, I have started a job of 45m² with 600 x 600 porcelain. I'm having trouble when I'm cutting the tile. I'm left with a tail at the end of the cut and at this rate I won't have any tiles left. I'm not sure what I'm doing wrong. Is my wheel height set wrong ? Is it just bad technique? Need help bad ! I'm using a sigma 3c3m BT
It hasn't seen much use to be fair, im DIY so it's only had one other job. I think I might have solved it. I was scoring a lead at the front and back of the tile which I think was giving me the problem. Does that make sense?
Did you fix this problem as I am having this issue with the same cutter. Leaves a tail on the end every cut.
Reply to Need help with cuts in the America Tile Forum / Advice Board area at TilersForums.com
Hi there Homeowner here who recently had my kitchen tiled by a professional tiler. We’ve been...
Hi, I'm tiling the floor of a wetroom and would like some advice on the best way to lay the...
Hi, it's my first time here and I'm desperate to solve this problem. Can someone please tell me...
USA Tile Forum Popular
America Tile Advice Trending
Belfast
What member type are you?
  1. Homeowner
  2. DIY Wall and Floor Tiler
Business Name
chrisc123
Need help with cuts
    Votes: 5 4.7%
    Votes: 8 7.5%
    Votes: 6 5.6%
    Votes: 29 27.1%
    Votes: 14 13.1%
    Votes: 27 25.2%
    Votes: 3 2.8%
    Votes: 2 1.9%
    Votes: 19 17.8%
    Votes: 18 16.8%
    Votes: 13 12.1%
    Votes: 5 4.7%
    Votes: 3 2.8%
    Votes: 1 0.9%
