New bathroom installation - Floor question
richardlee
Hello Guys.
I have just removed my bathroom flooring, back to bare joists. The room is 8'x6' and I will be laying 16" square travertine tiles.
I have read through the posts and spoken to a few people on what to fit as a base, it's all going to be new, wastes etc so floor height isn't really an issue but the lower the better.
I was thinking of the following:
18mm ply screwed to the joists with zinc screws and tanked, then tiling directly onto this. I thought that the ply would provide the rigidity whilst the tanking would prevent moisture ingress into the ply. Is this a good way to go?
I have seen recommendations on using tile backer but from what I have read, tile backer is good when battened to a wall as is does not fail when saturated but on top of ply it seems that it would simply be providing a good tiling surface, but I would still need the ply for rigidity, so the tanked ply would be good enough anyway. . . ?
I have also read that some just tile directly to marine ply, any thoughts on this?
Thanks guys.
Richard.
Hardiebacker Cement Board for tile and stone is to be used to have a water resistant proper surface to tile upon. It has very little insulation properties.Hardiebacker would heat up quicker and transfer heat better than wood as it has a higher thermal conductivity value, woods acts more as an insulator.
Hardie Guy
