Discuss new blurk from northeast... in the UK Tiling Forum area at TilersForums.com.
yes you will need to for cement based adhesive. you can get the primer from the tile shop where you get your adhesive from, and as sir ramic mentioned you should think about tanking (waterproofing) the wet areas prior to tilingCheers Rich,
so if i get a cement adhesive instead, do i bond the walls then..?
Its a finishing plaster thats on the walls, thanks.
Reply to new blurk from northeast... in the UK Tiling Forum area at TilersForums.com
