Discuss New houses... in the Canada Tile Advice area at TilersForums.com.
It's not just me then? Lol
How are you guys prepping these? On the last one I did, I drilled holes in the plaster boards and squirted expanding foam In. It made the wall a bit stiffer, but still could've done with something else I think.
There's not really anything to attach studs to Dave!?! Only thing you can do is gripfill them in place, which doesn't really improve the rigidity. I may well
Horizontal framing .. from stud to stud...
We use CLS and it does work .. but it does depend on the metal lay out.. and if you can get a fixing to sole plate and header... also double boarding helps..
Dave, do you cut into the metal and slot the CLS in? And do you trim the CLS down, as i find it about 2/3mm too thick usually, which causes bows in the wall. This stuff really is the bane of my life lol!
Use the CLS along the wall length and this will build out the that depth , if you get my drift... so the CLS depth is further out than the steel / notch around the metal..
best bet is to slap the house builder for using it in the first place :lol:
Dan, I hear ya! Although they haven't built solid brick houses round here for a very long time. I'm ok with normal wooden stud though. At least it's easy to add a few noggins if necessary..
Reply to New houses... in the Canada Tile Advice area at TilersForums.com
