Discuss New member forum Advice in the The Welcome Forum area at TilersForums.com.
N
niaz1982
hi my name is Niaz and and I am new to the website. I'm in the process of doing up a family home to move my wife and kids into end of September.
I have a question which involves bathroom tile removal and prep. I've stripped out the bathroom myself removing all sanitary ware and have taken the tiles off the wall. I just need to remove high level wallpaper. Where I have removed tiles in some places the grout has been left behind. In other places the plaster has come away and gone back to the sand/cement render on the block work. I've rubbed this down with a wire brush so any loose chunks have come away but I am unsure if I should try to remove entirely? I sent pictures to the plasterer and he just said to get the green pva and apply it the day before he comes? I just want to make sure I have got it right prep wise for plastering out, skin then ready for tiling. Thanks for your advice.
Dumbo
In my experience most plasterers do not make a flat surface to tile to anyway . They just tend build it out and smooth to the touch not necessarily flat and definitely not plumb and square . So save your money and as above spend it on tile backer board to get it right and build a job that will last as long as you want it to
N
niaz1982
Hi there thanks for the replies, I was planning on using some bathstore tiles I've seen, they are 248 x 498mm not sure on thickness but they are ceramic. The plasterer I would get through work as we have them however we also have dryliners so I could get someone to tilebacker board it, just means I need to spend the next few evenings getting it all off. Seems to me that tilebacker board may be the best shout then, I was worried about the plasterer bonding it and plastering out and whether it would hold up. You all seem to agree tho on the way forward! Thanks for your help.
N
niaz1982
As above - you don't need a plasterer.
Use a tile backer board and fix ( inc mechanical support) direct to prepared walls. Just tell him your tiles could be too heavy for skimmed plaster walls - 22kg maximum weight tolerance .
Hi when you say prepared walls do you mean the block work?
N
niaz1982
Sorry one other thing I wasn't planning on taking it all off where the wallpaper is, I wanted to paint that around the window reveals and across 2 of the walls. Tiling was only to 1.40 metres remainder was to be paint. Should I still get that plastered or just take all off and screw fix moisture resistant board above the tile backer board? I could then just tape & joint this?
N
niaz1982
Dry liners probably won't have experience in fitting tile backer boards . It is a slightly different process using different sticking materials and mechanical fixings
We do office fit out including toilet partitions and have done this before so not too worried about that I'm happy our guys are skilled enough it's just where the wallpaper is I have a feeling that is going to come away so whether to bond that out and skim or to hack it all off and put a mr board above the tile backer ?
N
niaz1982
I've done a few site new builds and have yet to see dry liners that have fitted tile backer board using tile adhesive and mechanical fixings . As regards your other question. Dry line and joint will give you a quicker drying time .
Thanks jcrtiling - you haven't met this fixer
Reply to New member forum Advice in the The Welcome Forum area at TilersForums.com
This is the Plumbers Forums is now Plumbers Talk Discussion Thread As always; a simple ‘logo’...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
