Discuss New on the market...but any good...???? in the UK Tiling Forum area at TilersForums.com.
Perfect Tiling
Just been in my local stockists and was shown a new product called plastic ply (well...new up here). Its a 2mm thick plastic mesh with a self adhesive backing. Apparently you just peal the paper off the backing and stick it onto clean chipboard or plywood...no adhesive, screws or anything. Then you just tile over it as normal. Its supposed to replace the need for 15mm plywood or tile backing boards. I can't see that I would trust it...what happens when the self adhesive gives up...you will end up with a floating floor. Anyone ever used or heard of this stuff...apparently its been fully tested and certified. No idea of price yet. :yikes:
Rizzle from the Portizzle
gary used that at ideal home show london on a floor for a stand chipboard floor not fixed just layed loose then put the plastic ply down then 4.8mm porcel-thin tiles 1200x 600 the floor took a pounding over 17 days did not move held the floor down and togther you are not allowed to fix floors in exhition halls
AliGage
Subscribed
4,531
1,188
Peterborough, England
I've used it once before in the bathroom above. It's quick and easy to use.
Effectively id say it's the same as ditra/durabase matting, which is what i would prefer to use. Would imagine, trade-wise, ditra would be cheaper?
Reply to New on the market...but any good...???? in the UK Tiling Forum area at TilersForums.com
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent...
Hi All So around 10 years ago (i had no idea it was that long ago until i looked up the order...
    Votes: 5 4.6%
    Votes: 8 7.3%
    Votes: 6 5.5%
    Votes: 30 27.5%
    Votes: 14 12.8%
    Votes: 28 25.7%
    Votes: 3 2.8%
    Votes: 2 1.8%
    Votes: 19 17.4%
    Votes: 18 16.5%
    Votes: 13 11.9%
    Votes: 5 4.6%
    Votes: 3 2.8%
    Votes: 1 0.9%
