Blunt Tool
Discuss New Range Gemini Studio wave tiles 900x300x12mm in the Canada Tile Advice area at TilersForums.com.
Yes I know but can't cut straight as will be tight at tiles highest points and around 8mm gap to next highest point unless profile cuts to suit but wave will be slightly off unless I run the silicone and smooth off with my elbowThat's asking for trouble. You'll need to have all internals perfectly plumb for that to happen!
The bit that comes off has all the ridges on the same place/line as the bit fixed, just use an angle grinder to cut the 8-17mm ridges out of the return piece. No fancy graphics like @Paul C. but I'am having a cup of tea.
Don't know if I would have them all round maybe feature wall then rest the plain tile.I've seen those tiles on a local showroom display......they looked that nice I thought about having in my bathroom,when I get round to it!
Usually use the Siri ones with screwtop, but interferes with the wave profile so had these in van and try to place in flattest areaThose lash clips are nasty. Really should get onto rls or PLM clips. You won't believe the difference.
Reply to New Range Gemini Studio wave tiles 900x300x12mm in the Canada Tile Advice area at TilersForums.com
