Discuss new wet room in the British & UK Tiling Forum area at TilersForums.com.
s collins
hi guys im looking for a bit of advice
i have a down stairs shower room which i had to rip out due to a poorly fitted waste pipe
and im now hoping to install a wet room
i have removed the screed and have around 90mm to finished floor level
i have installed wet ufh to most of the ground floor level so was wondering if this was ok for the wetroom as i cant find much about wet ufh in wetrooms most seem to mention electric which seem to go on top the tanking
will there be a problem with the heat being under the tanking
im also looking for ideals on what former to use or is it better to use something like impey level grade
and also what type of tanking would be best
room is 2400x1700 aprox
thanks simon
Mike Mike
i still cant find tanking or membrane that seems to work with plumbed UFH
and anyone point me in the right direction ?
thanks
Vinyl flooring works perfectly well with underfloor heating as a tanking system. I have tiled literally hundreds of wetrooms with vinyl on the floor, and many with vinyl on the walls too. It's usually Armstrong "Tätskikt - Golv" (possibly called Waterlite in the U.K.).
Here that costs about 230kr/m2 for the safety floor and 250kr/m2 to fit it. Your floor is 5.2 m2 (including the turn up on the walls), so that solution would cost you 1380kr for the vinyl + 1300 fitting = £251, all in.
That is 100% waterproof, works 100% fine with piped water UFH and is the most robust and reliable tanking system. There have been many investigations and analysis by the Swedish insurance companies and national building regulators and less than 2% of water damage occurs with this system compared to nearly 40% with the roller type paint on systems.
If you pursure finding out about this type of solution I would be very interested to hear what the costs are in the U.K. i.e. if they cost half what they are here, like most things seem to, or, as it isn't popular there, whether it's actually dearer??
Maybe you should float the idea on the Flooring Forum to see if they have heard of it??
Good luck!
Mike Mike
thanks mike i forgot to mention that the floor and wall will be finished in tiles
Simon, yes I understand, the vinyl is the tanking system, hot welded in the corners, and is tiled over.
Here is a list of (Swedish approved) vinyl tanking products, they are all manufactured by foreign owned companies like Armstrong, Tarkett, Forbo, Gerflor etc so they must be available in other countries other than here in Scandinavia Godkända plastmattor som tätskikt under kakel och klinker - GVK.se (In fact, I KNOW they are. All your hospitals, private medical centres, care homes etc use their safety flooring systems as there are hygene regulations that must be met).
Here are the approved adhesives for tiling onto vinyl tanking: Fästmassa på plastmatta - GVK.se
Not all will be available in the U.K., but Mapei, Weber, Bostik and Ardex will be.
I know this system will sound double Dutch to you Brits, but in Scandinavia 100% of bathrooms are wetrooms. Indoor wetroom bathrooms were the norm here when you had outside toilets and bathed in a copper tub once a week in the kitchen (be honest, I know people who have admitted to me that was fairly common in England even into the 1950's!).
All the tanking products I have seen mentioned on this website are either old hat (roller type systems from 20 years ago, although companies like BAL think they have just invented the wheel), or are laborious to install and require numerous little extras (like preformed corners) which soon bump the price up.
The minimum I would use on a wetroom floor is a folie stystem (to me that's a membrane, but I think you call the roller / paint on stuff a membrane, which is not the same thing). Godkända tätskiktsfolier under kakel och klinker - GVK.se
By the time you have purchased it, the adhesive to stick it on, the internal and external corners and pipe covers, and put it down, and jointed it etc, I cannot see how this could possibly be quicker and less expensive than a vinyl system. A vinyl floor in a bathroom your size would take about 2 ½ hours to install.
Reply to new wet room in the British & UK Tiling Forum area at TilersForums.com
I have a walk in shower room ... Sort of a wet room but not quite. I used a kerdi style wet...
  • Sticky
Shower Tile Repair - Tile Waterproofing in Brownstown MI. Schluter wet room conversion 24h...
Advice needed, noticed some grout that was cracked and tiles becoming loose in our en suite wet...
new wet room
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
