Mr.Moo
Hi all,
First post, so please be gentle :smilewinkgrin:
I'm about to tile above our new shower/bath and was looking for some advice as to how to prepare and waterproof the walls.
Have scoured these forums, I see that aquaboarding and/or tanking might be the way forward.
I've attached a photo as I've got one wall to be boarded, and the other is plastered brickwork.
I have bought aquaboard from Wickes to cover in the mixer controller on the stud wall, but what should I do with the brick wall? How do I seal from aquaboard to plastered wall?
Any recommendations for a waterproof adhesive? I have used tubbed Nicobond so far in non wet areas. Is the Nico Aqua Ultragrip a good choice I should I use a powdered adhesive around the shower end of the bath?
The tiles are travertine tiles so will pick the most solid tiles I can round that area and all are sealed after tiling with enhancer. The grout I was using (as recommended by my tile supplier - and it does look good!) is limestone ultra flex joint which says its suitable for power showers, swimming pools etc so assume is good enough grout.
Thanks in advance.
Thanks in advance.
