Discuss Newbie after advice in the British & UK Tiling Forum area at TilersForums.com.
jasonjohns
HiGuys
I did a week tiling course lastweek with the view to going into it full time. However i want to do a few jobs on the side first to build up some confidence.
I have a kitchen floor to do which i have removed the lino on, toreveal what looks like a hardboard base. Is it fine to tile onto this or do i still need to ply it as i was taught?
Thank you in advance
Jason
H
Home Tiler
Well if i was doing the job i would probably remove the hard board then ply it (15mm ply to be on the safe side) ....But if the hardboard is solid and no movement or bowing then just put 12mm ply over it ...you have to make sure the floor is solid so deffo ply it either way mate... wait for a few more posts as this is my opinion and i've just started out myself
steve
jasonjohns
Thanks for advice
I dont think removing it is an option cos it runs under all the kitchen units. Its a relatively new built house so im only guessing its hardboard-not really sure what they use. It does seem solid though. You still think i need to ply over it anyway? Just concerned with raising the floor that much....
H
Home Tiler
Not knowing what the job "hardboard" or boarding looks like it's making it difficult to advise on what to do...however some of the more experience tilers on this forum will understand exactly the boarding you are on about and will advise approppiatly....however it does sound as if the boarding is solid enough for tiling....i would still ply it yes but use 12mm instead of 15...
please wait for more relplies..
steve
GazLC81
Some would just tile straight on the hardboard. If I remember rightly there is a certain type of hardboard in new houses that it "OK" to tile straight onto. I think it has a green colour to it.
Personally I would still ply it out as Steve said. Better to be safe than sorry!
Gaz
PS If you wait till a bit later the more experience tilers will be about an they really know there stuff!
DHTiling
You cannot tile onto hard board as this is a compressed paper product and will just swell with the moisture from the adhesive etc.. It is easy to remove as it will just snap off at the unit legs .. so remove and ply out with 12mm ply....prime edges and back of ply with bal bond sbr neat and screw down every 300mm.....
GazTech
I concurr....do not tile onto hardboard mate get it up,and 12mm backerboard down with SPL or Rapid flex is fine
steg90
Yes, remove the hardboard and ply with 12mm ( 25mm screws I believe ) prime the ply and then use single part flex adhesive :) If you left hardboard down and plyed over, the floor would be raised quite a alot...Any doors going to be affected by putting the floor down? i.e. any need shearing down? Also, any white units going to become 'lodged' in after tiling? You probably already aware of this, just thought I'd mention it.
jasonjohns
Well here is the finished job. Not bad for my first attempt i thought. Tell what you guys think
Reply to Newbie after advice in the British & UK Tiling Forum area at TilersForums.com
Newbie after advice
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
