Discuss Newbie Bathroom Installation... in the Bathroom Tiling Advice area at TilersForums.com.
willnozz
Hello,
I am installing a new bathroom in the first floor box room at the back of my victorian terrace (existing bathroom in the room beneath) with separate bath and shower enclosure.
Having emptied the room and pulled up the carpet, hardboard and floorboards for first fix plumbing, joist strengthening etc. I have noted that the boards are in pretty poor condition and have evidence of woodworm at some point in the past. As a result, I have decided to get rid of the floorboards and lay new board straight on to the joists.
I have had so many different opinions on what to use at this point that I don't know where to go from here...
Some say floor grade chipboard, some say 18mm WBP, and my plumber has recommended "Dukkaboard", though this seems pretty expensive.
We're not on a huge budget, so the tiles we go with (haven't decided yet) will be at the cheaper end of the spectrum, but safe to say they will be porcelain and on the large side (600 x 400/500/600)
Can anyone advise the best way to go with this? Ideally I do not want to raise the level of the floor too much, and would like to keep costs down.
Many thanks,
Will
Rich
I havnt use Dukkaboard but I would go with BWP ply 18mm min then over board with a cement backer board. The cement boards will need to be glued and screwed down, the glue will fill any voids under the boards. Adding extra noggins is also a good idea.
Even if you go for the cheapest tiles on the market, it will be a total waste of money if you dont prep the floor properly, I think this will give you a good substrate to tile onto. :thumbsup:
Reply to Newbie Bathroom Installation... in the Bathroom Tiling Advice area at TilersForums.com
Hi everyone, With a kitchen renovation, Mrs choose the white mirror quartz floor tiles from a...
Hi all, probably a pretty common question but I'm going around in circles looking online for a...
Hi Everyone thanks for having me on the this forum ill try not to break any rules. I am diyer...
Unsolved
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
