H
htelford
Hi all,
Pleased to be on a professional forum.
Would appreciate advice if poss!
Have tiled 2 en-suites (at home) with a cement/grout. It is very hard and if cleanedf off before it has dried, cleans out the gaps.... When dry leaves pin holes and bare areas of grout. If left to dry, is it impossible to remove without recourse to stainless wire wool!! Anything I should have done to avoid this, as I have the bathroom yet to do, and removing the grout film and re-grouting etc is getting tedious? The other factor is in sealing the finished grout!
From the forum I see I require a penetrating sealant. Any advice as to what is available would be very appreciated, as I would rather only do it once every 10 years; and experience is worth more than 100 slick salesmen!!
Thanks guys.
Thanks guys.
