richburgan
Hi All. New to this site, already learned a lot as I am new to this tiling lark!
Planning new bathroom project and advice would be much appreciated, so far:
Tiles - Travertine light filled and honed 400 x 600 x 12mm
Adhesive - Stonefix standard set flexi white bagged
Grout - Stonefix flexi (beige)
Tile seal - Lithofin Stain Seal
Plastered walls are blown and poorly fitted floorboards - Remedial action planned:
1.Rip up floorboards and fix 25mm WBP ply to joists and use Schluter Ditra mat.
2.Strip walls back to brick/breezeblock and dryline with Gyproc moisture resistant plasterboard (using Gyproc Dryline adhesive), tank area around showerbath with BAL kit. Box section around back of toilet to hide side entry soil pipe.
3.End of bath butts up against airing cupboard which is currently water damaged tiled MDF (power shower is mounted on this). Planning to rip this section off, replace with 18mm WBP Ply which will be tanked.
The areas I need clarification on are:
1.What do I do about expansion joints? (I'm not planning to have skirting) I like the look of the Schluter systems for wall corners, wall/floor joints and around bath but finding it hard to source a supplier (and I expect that they are pretty expensive!)
2.Is it adequate to dryline with the dot and dab method (can't afford to add much thickness to walls due to tight aperture for bath) or would it be advisable to add some mechnical fixing as well?
3.Is it okay to tape joints in plasterboard with usual mesh tape before tanking?
4.Will it be okay to box the soil pipe in with plasterboard over timber frame and then tile?
Apologies for all the questions but want to get this right first time.
Regards Rich.
Regards Rich.
