I
Ian Marsh
Hi all. I'm an amateur, although I've done quite a bit of tiling in the past with small ceramic tiles, but as I'm redoing a bathroom and using 30 x 60 cm porcelain tiles I thought I would get on the forum and research the process a bit more so that hopefully I don't **** it up !
The job is for myself and I'm retired so not trying to do it in a hurry.
I made a start this morning which was a bit of a disaster. I have unwisely got fastset adhesive (20 kg bags of 'tilechoice') and mixed 10kg of it with the prescribed amount of water, both accurately measured out but the mix turned out much stiffer than I expected and the whole lot became unusable in about 20 minutes plus was a real struggle to apply. I suppose I should have followed my instinct and put more water with it . I'm thinking now to make up another smaller mix, with more water , but maybe wet the aquapanel and tile back as well? Any suggestions would be gratefully received!
