Discuss nonsanded vs epoxy grout in the Tile Adhesive and Grout Advice area at TilersForums.com.
I am looking to dig out about 1/4 inch of existing and re grout. My issue is its an off white color and always getting dirty and well you know. I read that epoxy is the way to go.
Can you put epoxy grout over old nonsanded grout that's left in the joint after I use an oscillating saw to remove a 1/4 inch or so?
Is it much more difficult to install epoxy grout? I typically mix up the nonsanded and use my finger to put down in the past with a sponge to pick up the excess.
Thanks !
Reply to nonsanded vs epoxy grout in the Tile Adhesive and Grout Advice area at TilersForums.com
Hello, I did some reading here and there, but the opinions seem to diverge at some point and I...
Hi any info on get rid of epoxy grout haze on natural stone would be much appreciated. I’ve used...
Unfortunately the tiler did not follow the manufactures instructions for mixing up the two part...
Hello, after tiling the kitchen area I did grouting but I am not happy with the results. The...
Hi - I ripped up laminate flooring on a concrete subfloor. It was my first DIY project and...
Tile Adhesive Trending Topics
cleveland
What member type are you?
  1. Homeowner
Business Name
NANA
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
