Discuss Norfolk Showering Bath - How to create a good seal to the wall. in the British & UK Tiling Forum area at TilersForums.com.
L
ljmountain
I am about to install a bath as pictured in Mark Bs album Picture 4 of 6 from Bathroom 1. It would appear the way to do this is to tile first and then fit the bath (bath legs will be screwed to floor) - see original post http://www.tilersforums.com/tiling-forum/9582-tiling-freestanding-shower-bath-2.html.
I am looking for advise on how to go about sealing bath to a pre-tiles wall, all the posts I see so far advise not to do this hence no advise for the procedure.....
Is this what I should do?
1) Get bath as close to wall as possible - pray that wall is flat......I just had it plastered but am wondering if I should have used tile backer instead.....
2) Secure bath to floor
3) Fill bath, leave to settle for 2hrs
4) Use v.good quality Silicon and use loads of it to make a really good seal.
5) Wait 24hrs before emptying bath
Thanks for any advice. By the way any advice on quality Silicon or relevant forum posts?
doug boardley
wind the bath up, hopefully it won't need chopping into the wall, to about 3mm from the bottom of the tiles and then Silicon. No need to use "loads", just use enough to make a seal and an aesthetic finish. If it doesn't need chopping into the wall, give the wall facing flange of your bath a good bead of Silicon too.
sheffjon
I just fitted one of these and it was a royal pain. I used tile backer board and it made no difference that my corner was square, as the bath moulding was not square anyway. Neither were either of the edges horizontal, more like long banana curves on each side. Good luck trying to put a spirit level on them! To add to the fun none of the feet matched each other (despite waiting a fortnight for more bathstore deliveries and trying 3 different sets) so I had to sand the base of them down a bit at a time in order to level the bath as best I could and not have it rocking on 3 legs. The moulded profile of the edges against the walls has a very large radius for some reason, so even tiling after fitting means you will not have the tiles overhanging the bath edge radius. This, combined with the banana shaped edges, means a very wide concave Silicon joint is needed around the bath. Once fitted the whole lot creaks alarmingly when climbing in and out; however tightening all the feet as much as you dare (not too much or to bathstore's specified torques or you fill crack the feet as I did with my first set), then siliconing them to the floor, and the bath to the wall, then the tile edge/bath joint, then leaving the whole thing full of water to set for 3 days, seems to sort the creaks out.
Is it worth the hassle though?
Reply to Norfolk Showering Bath - How to create a good seal to the wall. in the British & UK Tiling Forum area at TilersForums.com
  • Sticky
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
