Discuss Off-grid Giandel inverter with 2 AC outputs wired into 2 separate RCBOs - weird or normal RCD behaviour? Electrical Advice in the Electrical Advice area at TilersForums.com.
Off-grid Giandel inverter with 2 AC outputs wired into 2 separate RCBOs - weird or normal RCD behaviour? Discussion ThreadOff-grid Giandel inverter with 2 AC outputs wired into 2 separate RCBOs - weird or normal RCD behaviour? Electrical Advice
Hi All,
Looking for some advice into my build.
What I've basically done is add additional RCD protection to my 100% off-grid 12V 3300W Inverter system by adding RCBO breakers to both AC outputs of the inverter (12V Giandel 3300W 240V).
Things you should know for context:
  • Inverter has no N-G bond
  • Inverter has no RCD protection
  • Inverter 2 AC outputs / receptacles
  • each AC output is running into separate RCBOs via the consumer/sub panel (see images & schema)
  • N-G bond made in the consumer panel
My assumption
- If a get a ground fault on one of the AC outputs, then only the RCBO for that output should trip
Here's what is actually happening:
  • If I simulate a ground fault on AC output 1 (I do this using the Low Impedance (LoZ) feature on my Digital Multimeter (DMM) by touching the DMM prongs on the RCBO), then both RCBOs trips
  • Same behaviour goes for AC Output 2, i.e. if I simulate a ground fault then both RCBOs trip
Here's my questions:
  • Can someone please explain what is going on here? I don't understand why a ground fault on one of the AC outputs is causing both RCBOs to trip. It's as if both AC outputs are on the same circuit?
  • Is this behaviour because of the way the inverter is internally wired OR because I added a N-G bond? Can I do additional tests to confirm which?
  • Am I causing potential safety issues with my wiring?
Kinds Regards
GeeGee
Basic Schema
[ElectriciansForums.net] Off-grid Giandel inverter with 2 AC outputs wired into 2 separate RCBOs - weird or normal RCD behaviour?
Consumer Panel
Off-grid Giandel inverter with 2 AC outputs wired into 2 separate RCBOs - weird or normal RCD behaviour? for the original thread on Electricians Forums
Reply to Off-grid Giandel inverter with 2 AC outputs wired into 2 separate RCBOs - weird or normal RCD behaviour? Electrical Advice in the Electrical Advice area at TilersForums.com
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
