Guest viewing is limited
Discuss Ok so I made a mistake. Cutting a tile while it’s on the wall? in the Canada Tile Advice area at TilersForums.com.
Ok so I embarked upon my first tiling job the other day.
it went really well and I’m happy with it.
As far as I can see I made one stupid mistake.
I haven’t taken enough out around the sockets and I can’t get my sockets back on. I need to take around 5mm off the tiles along the bottom of the sockets. BALLS.
Any tips on this? I was either going to scribe it with a tile scribe and straight edge, or feather it down and my angle grinder. A bit scared of the angle grinder because of the dust in my kitchen.
If it was me, I would use the grinder with someone else holding a hoover to catch the dust but you've got to be really careful cutting a tile once fixed as it could jump and mark the surrounding tiles, if you've got a good blade and they're ceramic tiles then it should be pretty straight forward.
Imo you've got more chance of slipping and marking another tile with a tile scribe and straight edge.
They are ceramic tiles with a good blade. I also just thought, what about a multi tool with a tile blade? I might have more control.
Reply to Ok so I made a mistake. Cutting a tile while it’s on the wall? in the Canada Tile Advice area at TilersForums.com
Hi. I wonder if you can advise me. I need 4 inch hole drilled through the wall to install new...
I am about to start tiling the walls and have spent a long time planning the setting out of all...
6K
First job with this type of stone (have laid floor and wall tiles several times successfully)...
Hi I've been a 'tiler' for a very long time but in the last 10 years moved into maintenance and...
Bristol
What member type are you?
  1. Homeowner
  2. DIY Wall and Floor Tiler
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
