- 337
- 588
Got a hallway and utility to tile (1920's semi), hallway is normal floorboards and then goes into utility but changes to an old 40mm screed. This is cracked badly and parts are loose, under the utility is a celler and when you go down you can clearly see the bottom of the utility floor which is just a normal joists with old thick floorboards.
The screed is in really bad condition and needs to come up so can I just remove it and build up the 40mm (so its level with the hallway) in ply and timber?
What was the original purpose of the screed?
