Discuss Old house, traditional pine floorboards, 6mm ply, plus Ditra in the Canada Tile Advice area at TilersForums.com.
Time's Ran Out
I would say no!
But it depends on the size of the floor, how much deflection is in joists and the weight expected to go on top of the floorboards.
British standards is 15mm exterior plywood however there are better substrates available these days .
If it's just a 1metre wide hallway you may find 6mm hardie boards suitable. But if it's a 30 metre kitchen with 2 ton of granite worktop then a structural engineer may be required.
Busybee1
Thanks for the responses. It's a kitchen, 15' x 21'. The original floorboards have been over boarded with 6mm ply nailed down, then some very sticky stuff, then ditra matting, then adhesive, then the tiles. They are large tiles, about 10" x 20".
The tiler laid the tiles this week. A couple of other things made me question the work, but now I'm getting worried about the ply base thickness.
Does using the ditra mean you can use a thinner base? Are my tiles likely to crack?
Dan
Admin
Staff member
5,096
1,323
Staffordshire, UK
We posted at the same time there. So 100% not screws then. Not good news at all. Ring Schluter or the adhesive firm and get confirmation that their guarantees are now void and then find an actual wall and floor tiler not a bob the builder and get it done properly.
Reply to Old house, traditional pine floorboards, 6mm ply, plus Ditra in the Canada Tile Advice area at TilersForums.com
I'm about to tile my kitchen with 600mm x 600mm porcelain tiles. I am tiling onto a subfloor...
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
Hi, a long time since I have been here but back for some advice/reassurance ! About to tile my...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
