Discuss Opinion on a cl offset. 600x300 brick bond in the Canada Tile Advice area at TilersForums.com.
stuey72
Firstly apologies for the hand drawn half scale drawings.
1/3 brick bond in a small bathroom, there's always going to be a compromise but can't decide what's the best way to go with it. The window hits you straight on as you walk into the room therfore IMO the tile centred around the window looks correct however leaves 40mm cuts which will reduce down to approx 25mm when the next wall is tiled.
Offsetting everything to the right by 75mm gives better looking cuts of 115mm LH and 150mm RH (I would want to offset it further) but the centre window tile is noticeably offset.
There is a vanity basin and vanity toilet to go against this wall but Im not sure that'll detract from the 75mm offset.
The only saving grace about doing it the first way is that the wall to the left of the thin cuts could have a full tile butting against the cuts to continue the brick bond at full length.
What is your opinion on this please?
Stu
Thanks for the reply, In the end I kept the tile central to the window but didn't lay them out as in the drawings. Each course above the tile fixed shunts 200mm to the right which gives a pattern repeat 3 courses above.
I'll upload a picture later,
Stu
any chance of the pic??
Reply to Opinion on a cl offset. 600x300 brick bond in the Canada Tile Advice area at TilersForums.com
I'm tiling my bathroom using white metro tiles 20mm x 10mm (not bevelled). I want to use a...
Hi all, mostly done smaller wall tiles in the past so just wondering how flat a 600x300 floor...
Hi, Running a small bathroom job for a customer. Customer really wants to use a particular...
10K
All, I have 600mm by 300mm porcelain tiles for the shower area. The girlfriend wants a vertical...
Hi everyone, Im after advice tilling my kitchen walls behind hob, sink and under wall cabinets...
    Votes: 13 8.8%
    Votes: 11 7.5%
    Votes: 44 29.9%
    Votes: 17 11.6%
    Votes: 35 23.8%
    Votes: 20 13.6%
    Votes: 15 10.2%
    Votes: 7 4.8%
