Discuss opus pattern setting out/grout lines in the UK Tiling Forum area at TilersForums.com.
I'v got a opus pattern travertine floor to do, which includes going around a island. I was wondering what is the best way to go about setting this out. Also when i dry laid the pattern out with a 3mm spacer some of the tiles ended up with a 10mm gap and some had non, would i be better off going with a larger grout line,and just adjust the ones that dont fit right, as i go. Any advice is apprecated, thanks.
Daz
Set the floor out based on the smallest tile and you will always get good cuts.
I would dry lay the tiles in the pattern to establish the most suitable grout joint width so that the joints are predominantly balanced. If all else fails, speak with the tile manufacturer & supplier to establish what joint the pattern has been designed with.
The key is that the wider the joint the easier it will be to make it look balanced.
Good luck,
Daz
Reply to opus pattern setting out/grout lines in the UK Tiling Forum area at TilersForums.com
Dear Tilers, my husband has done a lot of tiling, but would really like your advice please. He...
I was hoping for some advice. I have large white tiles in my kitchen who a friend laid. I was...
I thought I did everything right--my 13 inch tiles came down and stopped 1/8" away from the...
Hi All, I have a question about setting out and would appreciate you guys input. I have a room...
Poynton, cheshire
    Votes: 5 4.5%
    Votes: 8 7.1%
    Votes: 7 6.3%
    Votes: 32 28.6%
    Votes: 14 12.5%
    Votes: 29 25.9%
    Votes: 3 2.7%
    Votes: 2 1.8%
    Votes: 19 17.0%
    Votes: 18 16.1%
    Votes: 13 11.6%
    Votes: 5 4.5%
    Votes: 3 2.7%
    Votes: 2 1.8%
